macOS Sierra (10.12)
Intel Iris Pro
Broken: (2.78 80837d0)
Worked: (none)
Viewport panning and rotation is broken (movement is super bumpy) on macOS Sierra only if continuous grab is enabled.
- in the settings panel under Input, activate the Continuous Grab option
- pan or rotate the 3D viewport (movement should be bumpy)
- by disabling Continuous Grab, viewport movement works as expected
Note
Trackpad gestures work fine. Using a regular mouse (middle-mouse-button + drag) triggers this behavior.
