Mac Pro (Late 2013)
Mac OS X Yosemite 10.10.5
AMD FirePro D700 6GB
Broken: (example: 2.69.7 4b206af, see splash screen)
2.78 GPU Compute
2.78 CPU
OpenCL fails to compile with the following errors in console:
Compiling base_kernel OpenCL kernel ...
Build flags:
OpenCL error (AMD Radeon HD - FirePro D700 Compute Engine): [CL_DEVICE_NOT_AVAILABLE] : OpenCL Error : Error: Build Program driver returned (517)
OpenCL error (AMD Radeon HD - FirePro D700 Compute Engine): OpenCL Warning : clBuildProgram failed: could not build program for 0x2021c00 (AMD Radeon HD - FirePro D700 Compute Engine) (err:-2)
OpenCL error (AMD Radeon HD - FirePro D700 Compute Engine): [CL_BUILD_ERROR] : OpenCL Build Error : Compiler build log:
Error returned by cvms_element_build_from_source
OpenCL kernel build output:
OpenCL build failed: errors in console
Build error: CL_BUILD_PROGRAM_FAILURE
Error: OpenCL build failed: errors in console
Terminated: 15
Any GPU Compute Cycles render
