Microsoft Windows 7 sp1, Radeon R9 280x
Broken: 2.76 48f7dd6, and all newer (2.76a, 2.76b, 2.77, 2.77a) up to 2.78 4bb1e22
Worked: 2.75a c27589e and earlier
Goal Strength parameter in “Soft Body Goal” works differently in 2.76+ versions
Parameter "Soft Body Goal > Goal Strength" greatly changed its influence from version 2.76.
For example, in new project: 0) del cube
- Add > Mesh > Plane, Subdivide it 3 times in Edit Mode
- Select 4 vertexes on corners and Assign to new Vertex Group
- Enable "Soft Body" in "Physics" pane
- In "Soft Body Goal" select created Vertex Group (all settings by default, nothing change in any field)
- Play animation
Problem: in Blender 2.75 and earlier (tested up to 2.71) animation is almost flat, slightly fluctuation. In Blender 2.76 and newer (tested up to 2.78) animation looks like long rubber deformation with big amplitude. At least "Goal Strength" parameter in “Soft Body Goal” change its influence when going from 2.75 to 2.76+.
