Ubuntu 14.04 64x
nVidia GT620
Broken: 2.78
Working: none ("Normal Map" node is a new feature)
By reporting T49801 I discovered this bug. It was an invalid bug because I had to change Normal Map texture to "Non-color". When I do that, the texture is not updated. I have to do some "other thing" to get the correct result.
- Run Blender with --enable-new-depsgraph.
- Open the file: . As I said before, we have to change texture color-space. So...
- In Image Editor panel, "Image" properties, change "Color space" to "Non-Color".
- Look at the spaceship of the left. It is not updated.
- Now, in Node Editor, click in the other output (the one of the right) and then back to the original.
- The Normal Texure is updated.
Now, using Blender with current depsgraph:
- Run Blender
- Open the file.
- The Normal Texure of the right spaceship is updated.
