Traceback error on exporting to .fbx
Intel(R) Core(TM) i7-4771 CPU @ 3.50GHz
8gb RAM
Windows 10, Nvidia GTX 650
Blender Version 2.78
Fail on exporting as .fbx, and makes Unreal Crashes if i export it as .obj
It's just a simple house, my first try modelling something, followed a youtube video steps
Vuk Gardašević (lijenstina) lowered the priority of this task from 90 to 50.Oct 29 2016, 8:50 PM
Confirming the issue.
line 1127, in fbx_data_mesh_elements
    def_mat = blmats_to_fbxmats_idxs[0]
IndexError: list index out of range
In the file the exact mesh that causes the error is the ground plane. It has two materials both of them linked to object, one is used (the green one - the other isn't).
To recreate the issue with the default scene:
default cube> add empty slot > set the link to object> add new material > add empty slot (the link now is object)> add new material > export to fbx
Seems that the case when the materials are linked to object and some of them are unused / not applied to the geometry triggers the error.
@Bastien Montagne (mont29) , I'm not assigning the task it's your call. :)
@Vuk Gardašević (lijenstina) thanks for checking and clearing the case, will check on it asap.
