Windows 7, GeForce GTX 760
Broken: 2.77 22a2853
When I load this file, it crashes on startup in 2.77. It also:
- crashes with Load UI unchecked
- crashes with Trusted Source unchecked
- crashes after resetting to factory settings
- crashes on appending the scene to a new .blend file
- crashes using older and newer versions of blender (2.74 and a steam version of .78a)
- crashes with all combinations of the above.
I've successfully loaded the .blend1 version of the file and rendered out what I had. However, the blender crashes as soon as you move over the Text effect strip in the VSE. It also appears in the file as {null} http://i.imgur.com/TASYrSt.png
Open the file. Sorry if that isn't very detailed; it's as far as I can get.
Thanks for taking the time to look at this, thanks for all your hard work and sorry if I've missed anything or made any mistakes.
