OS: Windows 64-bit
Graphics Card: Intel(R) HD Graphics 4600
Blender Version: 2.77a
Whenever I try to render an animation after an hour or so I come back and look and blender isn't open and I think it crashes. In samples, I set render around 400 and preview to around 200. Clamp direct to 0.83 and clamp indirect to 0.83 and I press animation and let it run. To add a little bit more of information I used Cycles.
Comment Actions
We need a clear way to reproduce the issue, with an example blend file. Also, 2.77a is old, please try the 2.78a release. Also, are you on Windows, Linux, Mac?
Comment Actions
Please fully answer in comments, editing original report is good but does not give us ways to see what part of the questions you addressed.
Also, looks like you still did not try 2.78a version? And please also try the latest build from our buildbot.
And finally, are you using CPU or GPU rendering with Cycles?
Comment Actions
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
