win 7 x64
Broken: hash: 62a2ed9
Loading an alembic exported from blender(especcially those objects) doesn`t loads uvs, in blender or 3dsmax (didn`t test other softwares)
in blender in order to load the uvs a need to do a weird procedure, in 3dsmax im looking for a solution to proper load them.
Export those two objects to an .abc file
2-open other blender instance and import the alembic file.
3- check for uvs
4- add a mesh secuencer chache and select the proper object to load
5-apply the modifier
6- select objects to check if any has uvs. .
7-Undo - now the uvs are load but not the modifier that we apply two steps ago
