Blender crashes on rt-click select
Envrionment:
Windows XP
Radeon 9000, running standard ATI Catalyst drivers
AMD Tbird 1.2
896mb ram
Blender 2.42
Reproduce rate: 100%
Reproduce steps:
1. Open Blender
2. Deselect default cube
3. Right-click on default cube
This also shows up when I select any other objects that I may have inserted into the scene.
Logged In: YES
user_id=103
This is very certainly a driver problem... we use standard opengl 1.0 code for selecting, something we get regularly reports for has issues in ATIs. Try if the ATI website has updates for your 3d card, also check on all settings you can tweak for Opengl... especially disabling the fancy stuff 3d games nowadays demand.
Further; check if older blender releases have similar issues. But, only use blender versions downloaded from blender.org!
Matt Ebb (broken) changed the task status from Unknown Status to Unknown Status.Mar 26 2010, 6:30 AM
