Windows 10, i7 3770k, 16GB, nVIDIA GTX 670
Broken: 2.78
I have six cubes nested together where Cube2 is the child of Cube1, Cube3 is the child of Cube2 and so on. Imagine they are placed in world positions A through F. If I export them as an FBX and re-import that same FBX, Cube1 is now in position A, Cube2 is in position B, Cube3 in A, Cube4 in B, Cube5 in A, and Cube6 in B.
- Load the attached .blend file
- Select any of the hierarchies prefixed with "Export"
- Export as FBX 7.4 binary, Use selection, Scale 1, Z Forward, Y Up, Enable "!Experimental! Apply Transform", Remaining settings can be default
- Import the FBX that you just created using default settings - ensuring "!Experimental! Apply Transform" is not checked
- Notice that all elements of the imported hierarchy only occupy the locations of the first two elements in the exported hierarchy
Note: This is my first bug report, so apologies if I missed something. I tried seeing if there were existing tasks discussing the same error but did not find any. I am attempting to get Blender to export FBX files that display correctly in Autodesk FBX Review and also import correctly into Unity without rotation and scaling errors.
