Global Undo turning off
Broken: (2.78 release candidate, 0e5089c)
Global Undo automatic turning off after using "loop tools"
2 cubes (or other objects) > edit mode > select 2 polygons > select "bridge" from "loop rools" > global undo turn off
Same problem with other options from "loop tools"
hi, testing, can you try a recent build from buildbot?
This comment was removed by CHET (cheteron).
https://builder.blender.org/download/ has downloads for nightly builds.
i tested looptools & each tool it contains & found that there was no error related to Global Undo turning off.
i have come across the global undo bug before in bsurfaces, so I'm familiar with it, it's just not appearing for me in this case.
Problem dissapear, thanks.
download version from buildbot:
version: 2.78 (sub 4), branch: master, commit date: 2017-01-14 02:34, hash: 0a446d7, type: Release
build date: Mon 01/16/2017, 04:01 AM
and there no problem
Vuk Gardašević (lijenstina) changed the task status from Unknown Status to Unknown Status.Jan 16 2017, 7:43 PM
Glad to hear that the problem is solved:)
Closing as archived.
If the problem show up again, you can post a comment on this task, so it can be reopened.
