The attached file has a couple updates and a fix to carver_mesh.py included in Blender 2.78a.
Updates:
- Use profiles from scene, rather than require user to edit script to add new profiles
- Adds a new scene property ProfilePrefix to set the prefix to look for profiles with
- Add ability to change depth of entire brush
- C is not an ideal key but D is used interchangeably for both the Object carve depth and profile thickness and I'm not sure it should be changed now that it's established
Fix:
- Fix issue with incorrect rotation brush rotation when the target object has been rotated (reported by Cirno, https://blenderartists.org/forum/showthread.php?400038-Carver&p=3109594&viewfull=1#post3109594) Note: The yellow/green ring displayed is still rotated incorrectly, I couldn't figure how to rotate it correctly.
