Blender 2.78, Exporting FBX creating extra bone
Closed, DuplicatePublic
Windows 10, GTX 870
Broken: (example: 2.69.7 4b206af, see splash screen)
Blender 2.78a and 2.73a
Blender 2.78, Exporting FBX creating extra bone. Bone is from the Armature object. This was reported in T45368.
I have a model from Neverwinter Night, bones and animation were imported from SMD. Everything looks fine, mesh, bones and animation, scaling was done to match mesh, vertexes autoweighted. Export FBX for import to 3ds Max, seeing extra bone. Renaming Armature object, Armature properties and root bone shows it come from the Armature object. Export is 6.1 ascii, same result with Blender 2.73. It was stated that it may be Max but looking at the FBX file shows it's in the file. Export should only have original bones, in this case the root bone has to be named c_chicken_skel. Trying to delete the extra bone messes up the animation frames, frames must be tied to the new bone.
Well, then you already had your answer in T45368, if it’s same issue…
Furthermore, you did not attach any file, so hard to tell, please follow our submission template and guidelines next time. And finally, FBX6.1 ascii exporter is only kept around for backup reasons, it is no more maintained nor developed at all.
