The position of Video Sequence Editor in the Editor type select menu is wrong, because it is higher order than the Movie Clip.
Is:
UV/Image > VSE > Movie Clip
Should be:
UV/Image > Movie Clip > VSE
Like:
Graph > Dope Sheet > NLA
A minor issue for the UI, but important for the manual, because it follows the menu order.
Then the Shift-F# hotkey (switch between editors) would need to be updated accordingly.
There could also possibly be a separator between the Image/Video editors and the Text editor.
