NA
Blender 2.78
Snap Element dialog does not match Mesh Select Mode dialog and does not work as expected.
In a new scene, enter edit mode on the cube with Tab
Use Ctrl+Tab followed by 1 to select the Mesh Select Mode for vertex select. (First option on list)
Set snapping to vertex snap by pressing Shift+Ctrl+Tab followed by 1 and it selects increment mode instead since it is the first option on the list.
Solution:
Change Increment mode to be the 4th or 5th option on the list to retain the vertex, edge, face order that is in the Mesh Select Mode.
