No motionblur on cornerpin node
all
Broken: all
The cornerpin node in Blenders compositor can't render with motionblur, making it unusable.
Just cornerpin somthing, move it around, render it and be sad that there is no motionblur.
The Plane Track Deform has an option for Motionblur, but in some cases it is just overkill to setup a track first. IMHO the two nodes should actually be merged into one...
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Mar 3 2017, 9:29 AM
Eeeeh… this sounds much more like a feature request than a bug report to me, @Sergey Sharybin (sergey)?
But if the node is broken because it is incomplete? It is actually only usable if it is not animated.
If someone can make a file showing this problem, it would be easier to investigate.
Germano Cavalcante (mano-wii) changed the subtype of this task from "Report" to "Known Issue".Feb 7 2020, 4:06 PM
Jeroen Bakker (jbakker) closed this task as Archived.Apr 12 2021, 3:31 PM
This is a feature request according the rules of the bug tracker.
For feature request please use the appropriate channels.
