Curve after array modifier makes setting dimensions impossible
Windows 10 64 bit, NVidia GTX 950m
Broken: (example: 2.69.7 4b206af, see splash screen)
2.78c
Curve modifier when added after an array modifier appears to make it impossible to size objects correctly.
Attached zip file contains two blender files with identical 3D scenes (one path curve + a cube array) along (1) the X axis and (2) the Y axis.
In both cases, if you try to change the dimensions of the cube array (by pressing N to display the transform panel, in order to enter new dimension values), the new dimension values that are entered do not register correctly (after pressing ENTER), while the Z axis size value changes arbitrarily (after trying to enter a new X or Y value, unsuccessfully).
It is understood that the dimensions of a single 3D object should be changed while in Edit Mode (e.g. by scaling), rather than through the transform panel when in Object Mode. Nevertheless, the weird and unpredictable behavior reported here should be corrected.
This issue may be related to https://developer.blender.org/T51020.
(Note: At some point while developing the blend-files attached, it appeared that the Y axis version presented additional problems, but I cannot replicate such issues any more.)
John A. Paravantis (paravantis) lowered the priority of this task from 90 to High.Mar 21 2017, 5:55 PM
Bastien Montagne (mont29) raised the priority of this task from High to 90.Mar 22 2017, 12:18 PM
Aaron Carlisle (Blendify) lowered the priority of this task from 90 to Normal.
John A. Paravantis (paravantis) renamed this task from Curve after array modifier is buggy when extended along Y axis to Curve after array modifier plagued by important sizing issues.Apr 16 2017, 6:30 PM
John A. Paravantis (paravantis) updated the task description. (Show Details)
John A. Paravantis (paravantis) renamed this task from Curve after array modifier plagued by important sizing issues to Curve after array modifier makes setting dimensions impossible.Apr 16 2017, 6:34 PM
John A. Paravantis (paravantis) changed the task status from Unknown Status to Resolved.Apr 20 2017, 4:07 PM
I have resolved the issue via a post at Blender Stack Exchange: To make precise dimensioning possible, one has to change the radius of the control points of the curve from 14 to 1!
