Bevel modifier: Unnecessary clamping
Windows 10 (x64) (version 1703), GTX 750Ti
Broken: 2.78c and latest build blender-2.78.0-git.2836003-windows64
When the bevel modifier's "Clamp overlap" option is active, clamping is applied even though it's not required.
  1. Open the attached file that I reduced to the most simple example
  2. Repeatedly switch the "Clamp overlap" option on and off to see that it affects the mesh.
I expect the option not to affect the mesh because there is no overlapping even if the option is inactive. This case is different to other reported cases as there is only one edge involved.
Please note that, if you move the three top vertices upwards (in Z direction), clamping is not performed anymore. However, this shouldn't make a difference in this case.
Thanks.
This should probably be merged with T50994 and T50819
Sergey Sharybin (sergey) lowered the priority of this task from 90 to Normal.
@Howard Trickey (howardt), mind having a look here? Thanks! :)
Howard Trickey (howardt) triaged this task as 50 priority.May 29 2017, 9:09 PM
This is different from T50994, as it is only about one edge (as reporter notes). It may overlap with one of the problems reported in T50819, premature clamping. I will look into this one now.
The problem is that the clamping is very naive right now: just clamps to the min of the half-length of all the edges involved in a vertex bevel. In this case, that means it clamps to the half length of the vertical edge, which doesn't even have advancing vertices on it, and it is a lot shorter than the edge that the vertices move along. It is a TODO to do much smarter clamping, but I'll spend some time now to see if cases like this, at least, can be improved.
Howard Trickey (howardt) changed the task status from Unknown Status to Resolved.Jan 30 2018, 3:47 AM
This was fixed a while ago, with smarter clamping code.
