Broken: rB4cf7fc3b3a4d032f0c0db632a46d40806e906cf1
Worked: rB4cf7fc3b3a4d032f0c0db632a46d40806e906cf1^
Using scene layers from a different scene doesn't show the output sockets.
Open the file
and re-set the scene of the right-most layer to use scene "B".This is what you get right when you open it, or in a commit prior to the bug:
This is what you get in new files, or after you re-set the (other) scene of the renderlayer:
