Blur node is causing black squares when using denoising
Windows 10 1607, GT730 MSI 4G
Broken: (example: 2.78 cf127f, Build of 19 may 2017
Worked: (Build of 18 may,)
Blur node is causing black squares when using denoise.
(blendfile)
Most likely to occur when doing following steps:
  • Make a mesh, like a chain (addon)
  • Shade flat
  • Give it a pbr metal shader , no roughness
  • Load .hdr or .exr environment map
  • Switch on Denoise with default options
  • Add a blur node in the compositor.
  • Everything renders fine , and denoise renders fine, but when compositor starts to do it's work , black squares appear.
Notes: gone when you switch the option on: Gamma or Relative in the blur node
Regards,
Robert
