On crash, Blender is not creating crash.txt file
Broken: (example: 2.78.5 bbce6ce249)
Worked: (unknown)
Upon a crash, blender seems to write to *filename*.crash.txt like it is supposed to from creator_signals.c
but the file doesn't seem to exist.
On crash, search for crash.txt
This is the code where it is supposed to write the file.
FILE *fp;
	char header[512];
	wmWindowManager *wm = G.main->wm.first;
	char fname[FILE_MAX];
	if (!G.main->name[0]) {
		BLI_join_dirfile(fname, sizeof(fname), BKE_tempdir_base(), "blender.crash.txt");
	else {
		BLI_join_dirfile(fname, sizeof(fname), BKE_tempdir_base(), BLI_path_basename(G.main->name));
		BLI_replace_extension(fname, sizeof(fname), ".crash.txt");
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.May 27 2017, 9:51 PM
It works for me, tested by running this in the Python console:
import os; import signal; os.kill(os.getpid(), signal.SIGSEGV)
How are you crashing Blender exactly? It may be that memory is corrupted to the point that even writing the crash log itself crashes, which we can't do much about.
I ran that in the python console, does crash, but still can't find the file.
Searching for crash.txt shows below:
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Archived.May 27 2017, 10:37 PM
macOS probably doesn't search the /tmp folder, that doesn't mean the file does not exist. With Finder > Go > Go to Folder > type /tmp you'll find it.
