Implement drag and drop in ID text fields (ID name and/or paths)
Confirmed, NormalPublicTO DO
Windows 7 x64
Broken: 705c43b
when drag dropping images in the texture node's path field, it should replace the current texture name with the dragged and dropped one, but instead it does like if you dropped in empty space and adds a new texture node.
Open attached file, replace one of the windows with a file browser in a location where you have some images. Then drag that image over the texture name filed of the texture node. Tooltip shows that the field is recognised correctly by changing from 'add new node' to 'paste name'. But if you drop, it will do as if you dropped in empty space and add a new node.
Joel Godin (FloridaJo) lowered the priority of this task from 90 to 50.Jun 12 2017, 3:10 AM
Bastien Montagne (mont29) lowered the priority of this task from 50 to Normal.Jul 4 2017, 4:34 PM
This not really a bug, more like unfinished/not implemented feature of drag and drop system. It does not only affect nodes, trying to drop an image filename into any text field of image ID selector fails (in texture buttons of BI e.g.). Works in Image space, but only because here calling 'open image' operator has desired effect.
Bastien Montagne (mont29) renamed this task from drag and dropping adds a new node instead of replacing hovered one in cycles. to Implement drag and drop in ID text fields (ID name and/or paths).Jul 4 2017, 4:34 PM
Bastien Montagne (mont29) edited a custom field.
Am I too early to ask if this is implemented but not working anymore (and somebody forgot about this task)?
When dragging an image onto a text field it DOES say "paste name" so that means to me that it's implemented or at least being implemented.
I worry that this particular feature is in a "loop" since it is in here that long without mentioning the additions of Campbell the 17th of april this year...
