Cycles denoising; Firefly/Highlight processing leads to pixels with negative values, values of -1.#INDO
Win10 64 bit; 24 gigs RAM; third-gen i7 CPU; AMD 7xxx GPU (Crimson ReLive drivers)
CPU Rendering
Broken: Hash c73206a
Worked: Never
When the denoiser processes scenes containing firefly-prone materials and bright highlights, it can lead to results filled with black pixels (some with negative values, others with values of -1.#INDO). Increasing the samples helps to reduce the issue of fireflies going black, but not with highlights that are small and bright.
Open the .blend file, render the scene, and examine the values of the many black pixels on top of Suzanne.
.blend
Adam Friesen (ace_dragon) renamed this task from Cycles denoising; Firefly processing leads to pixels with negative values, values of -1.#INDO to Cycles denoising; Firefly/Highlight processing leads to pixels with negative values, values of -1.#INDO.Jun 10 2017, 5:36 AM
Adam Friesen (ace_dragon) updated the task description. (Show Details)
Okay, there definitely is a major regression in overall quality due to one or both of these commits
https://lists.blender.org/pipermail/bf-blender-cvs/2017-June/097346.html
https://lists.blender.org/pipermail/bf-blender-cvs/2017-June/097384.html
Illustration
Before the commits (left image), fireflies just disappeared with no issue, highlight processing might've left a black pixel here and there, but their values were just slightly negative instead of INDO.
After the commits (right image), a number of fireflies and highlights now just go black instead of going away or being left alone. The quality issues that were resolved were surpassed greatly by the number that were introduced (and the regression affects every scene I might add, bright pixels aren't needed to trigger it).
Lukas Stockner (lukasstockner97) changed the task status from Unknown Status to Unknown Status.Jun 11 2017, 2:03 AM
Okay, this is somewhat improved with rB558bea2. I'll look into better handling in the future, but we're really close to a release and fixing the underlying issues will be really tricky (if it's even possible)...
I'll close this for now, but I'll keep the file for further tests.
(Sorry for the copy-paste from other reports, these are all related issues).
