Alembic sequence Crash
Fedora 24 x64, NVIDIA Qadro 4000k
Broken: 2.79 testbuild1 and git a96030b
Worked: 2.78c
Crash when loading an alembic sequence and move the timeline.
Load this .abc-sequence: 2frame_Alembic_Sequence
The frames are 1023 and 1024.
Crash message:
terminate called after throwing an instance of 'Alembic::Util::v10::Exception'
  what():  IPolyMeshSchema::get()
ERROR: EXCEPTION:
IArrayProperty::get()
ERROR: EXCEPTION:
std::bad_alloc
[1]    21514 abort (core dumped)  ./blender
Btw. the geometry inside the abc archive has vertexColors, UVs and velocity. Vertex colors are working inside Blender already, but you can use these files for testing if you are going to implement UVs and motion blur.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.
Please always attach files here, other places are not guaranteed to keep file around…
@Sybren A. Stüvel (sybren) can confirm crash, guess that one is for you. :)
Thomas Volkmann (knekke) changed the task status from Resolved to Unknown Status.Mar 6 2019, 12:52 PM
I have problems again with alembic sequences in 2.8. The sample files further up are crashing too...
Bastien Montagne (mont29) changed the task status from Unknown Status to Resolved.Mar 6 2019, 1:48 PM
@Thomas Volkmann (knekke) please do not re-open old reports, even if issue seems similar, it is quiet likely to be something different, so new report is *always* the way to go (you can easily link new one back to an older one if needed, of course). Plus, it makes things simpler to track down (a report that is fixed, then mark as not fixed, then fixed again… becomes confusing).
