- Machine: Lenovo Thinkpad X220 Tablet Laptop
- OS: Manjaro KDE
- Graphics: Intel HD Graphics 3000
- CPU: Intel i5-2520M
- RAM: 8 GB
- Branch: blender2.8
- Hash: a3d9ef2ea5
The "Reflection Cubemap" light probes do not properly reflect metallic objects. The objects that are metallic only appear to be shadeless and black in the reflections.
From file:
- Open Blender 2.8.
- Open the provided file.
- Observe the objects with light probes around them.
- You should notice that the reflected metallic objects appear to be black and shadeless.
From scratch:
- Open Blender 2.8.
- Add a cube to the center of the grid.
- Move the cube 5 Blender units on the Y-axis.
- Select the default.
- Split the view and open a node editor.
- In the node editor select "Use Nodes."
- On the metallic shader turn the "Metallic" slider to 1.
- On the metallic shader turn the "Roughness" slider to 0.
- Select the second cube and assign the same material that you just created.
- Add a "Reflection Cubemap" to the center of the grid.
- Go to the light probe properties and change the clipping start to 1.001.
- Change the influence to "Box."
- Go to the side of the default cube that is facing the second box and observe how it reflects the second metallic cube.
- The second metallic cube should appear to be shadeless and black.
