Combed hair from 2.78 not showing when appending
I have a file from 2.78 that has combed hair. It works fine if I open it in 2.8. However if I append it, it doesn't work.
Compare the difference between appending and opening this file:
Dalai Felinto (dfelinto) lowered the priority of this task from 90 to 50.
Dalai Felinto (dfelinto) created this task.
I tried your .blend with a yesterday's build made before depsgraph changes without problem.
I tried with hash f5f34a9 and obtain same result. Fine at opening and bad at appending.
I tried with CoW enable. Result is bad at opening and bad at apending or linking.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Resolved.Jul 20 2017, 3:18 PM
Quick workaround was committed at rB905366ca7e12.
