Render preview error
Sorry if this is not the appropriate place to report that, but I've already reinstalled drivers and blender itself and the error goes on every time.
Windows 10 and NVIDIA GeForce 940M
Broken: 2.78 (sub 0)
When using Cycles Render and trying to use the Rendered method to display, only when I change to GPU under the
'Type of active data to display' menu->Device, it doesn't shows nothing but the "chess" screen and the error: "CUDA: error at cuCtxCreate: Launch failed".
Opens blender->Delete all objects->Cycles Render->Add mesh (text)->Apply material to mesh->Switch Device to GPU->Choose rendered view
Bastien Montagne (mont29) lowered the priority of this task from 90 to 30.Aug 2 2017, 9:49 AM
Please:
  • Give us your exact Blender, OS and GPU (including drivers) versions, as requested in the template!
  • Ensure both your OS and drivers are fully up-to-date (and use official GPU drivers, not those provided by windows or tablet/laptop maker).
  • Try the latest build from our buildbot.
  • Try to start Blender in factory settings (--factory-startup commandline option) (this will ensure whether this is a userpref or addon issue or not).
  • Launch Blender from the command line with --debug-cycles option and attach as text file here any error printed out in the console (do not paste it directly in comment).
Also, not really convinced a 940m is suited for CUDA rendering, this is not very powerful GPU – but it should work, I think…
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Aug 11 2017, 2:31 PM
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
