Blender crashes whilst loading render kernals using GPU (AMD)
Windows 10 64-bit
i5-4570
R9-290X 4GB
Broken: 2.78c, 2.78-a372638, 2.80-48adef4, 2.77 (Tested on all, terminal output the same)
Running off CPU works fine and renders properly in render preview and full render.
Running off GPU in render preview works perfectly, but full rendering begins 'Loading Render Kernels' then after 5-10 seconds blender closes.
Works with default cube starting scene. I would not say my scene is complex and it works fine in render preview.
The output from terminal after running 2.78c with --debug-cycles:
Open file and press render.
Bastien Montagne (mont29) lowered the priority of this task from 90 to Normal.Aug 8 2017, 10:17 AM
@Mai Lavelle (maiself) maybe want to have a look here?
Mai Lavelle (maiself) triaged this task as 30 priority.Aug 8 2017, 12:08 PM
There's not really enough info to go off here, the only interesting thing in the log is "Error: EXCEPTION_ACCESS_VIOLATION" but that says almost nothing. Is there a another crash log somewhere? Please look for one and also check that your drivers are up to date.
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Aug 20 2017, 5:33 PM
More than a week without reply. Due to the policy of the tracker archiving for until required info/data are provided.
