Support for GTx 10series graphic card on render view
Broken: (example: blender-2.79-testbuild1)
Worked: (Yes)
Each time I enable render view on cycles, blender will just go into deadlock.
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Aug 7 2017, 6:08 PM
Please provide all the requested information, operating system, exact graphics card, and a .blend to reproduce the issue.
If it happens with the default .blend, did an earlier Blender version like 2.78c work? Perhaps try reinstalling the NVidia drivers?
I don't have this problem on Asus Strix GTX1070OC. Try to update the driver or reinstall blender.
I am using windows 10 x64, graphic card gtx 1050 ti blender version 2.85.
sorry i suppose to include this earlier. if i use my cpu it does not crash but once i change to GPU it crashes when i am using cycles view in blender 2.85
Please:
  • Give us your exact Blender, OS and GPU (including drivers) versions, as requested in the template!
  • Ensure both your OS and drivers are fully up-to-date (and use official GPU drivers, not those provided by windows or tablet/laptop maker).
  • Try the latest build from our buildbot.
  • Try to start Blender in factory settings (--factory-startup commandline option) (this will ensure whether this is a userpref or addon issue or not).
  • Launch Blender from the command line with --debug-cycles option and attach as text file here any error printed out in the console (do not paste it directly in comment).
Blender version 2.78.5
OS Windows 10
GPU Nvidia GTX 1050 ti 4GB
everything is up to date
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Sep 5 2017, 12:54 PM
More than a week without reply (to all requested points). Due to the policy of the tracker archiving for until required info/data are provided.
