Linux (Kubuntu 16.04)
Nvidia GTX 560 Ti
CentOS release 6.8
Tesloa K20m
Broken: 2.78, 2.79rc1
i imported a point cloud from a csv file using this script:
import bpy;
import csv;
def file_to_point_cloud(filename):
s = [];
if os.path.exists(filename):
f = open(filename, 'r');
for l in f:
s.append(l.strip("\n").split(','))
verts = [];
for p in s:
verts.append((float(p[1]), float(p[2]), float(p[3])))
me = bpy.data.meshes.new(filename);
me.from_pydata(verts, [], []);
ob = bpy.data.objects.new(filename, me);
bpy.context.scene.objects.link(ob);
return ob;
file_to_point_cloud('data.txt')Then I added a cube and i created a simple shader with an emission connected to the volume and the density of the emission is link to a point density node.
The point density node is then setup to objects verticies. The objects is the point cloud and every thing else is default.
It renders nothing.
However, when i start deleting some vertices on the point cloud, it starts working as expected.
I added suzanne subdivided 6 times and removed all faces and edges. the point density with Suzanne works.
Based on a (as simple as possible) attached .blend file with minimum amount of steps:
Using the attached blend file you should see the problem. Switching from Particles to Suzanne in the point density node (of the cube).
