WIN 10 latest GTX 780 DELL Xeon System
Broken: 2.79-0398ee1-win64-vc14
Worked: n.a.
I am rendering a scene in 16K resolution. In the beginning it was fine. Then I realized slow-downs in the transparent area of the picture.
When I move the window the tiles start to speed-up dramatically and render in a speed the empty area as expected.
When I stop moving the window it slows-down extremely. When the tiles start to render geometry the CPU performance in the task manager is at 100%.
When it comes to the transparent areas the CPU slows down dramatically till I move the window again.
But also here I realized now that the render speed in the geometry areas will slow-down if I keep the window in foreground.
When I close the window to background the speed goes up to 100% then.
But once it will reach the transparent area again in background the speed slows down to around 30%.
Crazy. I can't say if this is the size of the rendering. The scene render takes around 15GB of my RAM (32GB).
Attached you'll see screenshots of the CPU effect,
I can upload the complete scene if necessary. The render will
