Windows 10 x64
Git latest
The line layers[smd.layer] = bpy.context.scene.layers[smd.layer] = True (where smd.layer is 0) causes a 100% reproducible crash within Blender when the new dependency graph is enabled. There is no crash when the old graph is used instead.
- Start Blender with --enable-new-depsgraph
- Install and activate the Blender Source Tools
- Import any SMD file
Call stack
> blender.exe!DEG_graph_on_visible_update(Main * bmain, Scene * scene) Line 354 C++ Symbols loaded. blender.exe!DEG_on_visible_update(Main * bmain, const bool UNUSED_do_time) Line 380 C++ Symbols loaded. blender.exe!DAG_on_visible_update(Main * bmain, const bool do_time) Line 2573 C Symbols loaded. blender.exe!rna_property_update(bContext * C, Main * bmain, Scene * scene, PointerRNA * ptr, PropertyRNA * prop) Line 1812 C Symbols loaded. blender.exe!RNA_property_update(bContext * C, PointerRNA * ptr, PropertyRNA * prop) Line 1844 C Symbols loaded. blender.exe!pyrna_py_to_prop_array_index(BPy_PropertyArrayRNA * self, int index, _object * value) Line 2132 C Symbols loaded. blender.exe!pyrna_prop_array_ass_subscript(BPy_PropertyArrayRNA * self, _object * key, _object * value) Line 3053 C Symbols loaded. [Python to Native Transition] Annotated Frame import_smd.py!setLayer Line 651 Python Symbols loaded. import_smd.py!readPolys Line 726 Python Symbols loaded. import_smd.py!readSMD Line 1283 Python Symbols loaded. import_smd.py!execute Line 73 Python Symbols loaded. [Native to Python Transition] Annotated Frame blender.exe!bpy_class_call(bContext * C, PointerRNA * ptr, FunctionRNA * func, ParameterList * parms) Line 7644 C Symbols loaded. blender.exe!rna_operator_execute_cb(bContext * C, wmOperator * op) Line 985 C Symbols loaded. blender.exe!wm_handler_fileselect_do(bContext * C, ListBase * handlers, wmEventHandler * handler, int val) Line 1887 C Symbols loaded. blender.exe!wm_handlers_do_intern(bContext * C, wmEvent * event, ListBase * handlers) Line 2095 C Symbols loaded. blender.exe!wm_handlers_do(bContext * C, wmEvent * event, ListBase * handlers) Line 2176 C Symbols loaded. blender.exe!wm_event_do_handlers(bContext * C) Line 2449 C Symbols loaded. blender.exe!WM_main(bContext * C) Line 507 C Symbols loaded. blender.exe!main(int argc, const unsigned char * * UNUSED_argv_c) Line 529 C Symbols loaded.
