mesh modeling (subdivide limits)
the subD (number of cuts) has a max limit set to 100 even when I type the required number for my case
so fix this plz
I understand the limit on a number slider but the limit on typing my own value is a mistake
if you like you can add popup warning if the user type a number more than 500 for example
that will prevent people from putting a wrong value and will give us the freedom to put our values without any errors or restrictions
  • blender version ---
blender-2.79-dcebad7
ahmad (shehabsyr) updated the task description. (Show Details)
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Aug 30 2017, 5:30 PM
Thanks for the suggestion, but we do not accept feature requests or suggestions on this tracker (use forums or bf-funboard ML for that).
And having a hard limit on that setting is absolutely mandatory, even 100 on default cube will already generate 61k faces geometry, imagine what you'd get with a basic model of a few hundreds of faces… If you really need more, just apply it more than once.
