Background rendering with frame jump and sequencer is broken
Closed, DuplicatePublic
Linux Ubuntu 16.04, Intel integrated graphics card
Broken: at least from 2.76b to latest build
While rendering in the background from the command line a scene with a non-empty video sequencer, the jump parameter is ignored and the incorrect frames are rendered.
Consider the attached bug.blend file
and run in the terminal the command
blender -b bug.blend -a
Now all the 30 frames are correctly created.
If, instead, the couple of commands
blender -b bug.blend -s 1 -j 2 -a
blender -b bug.blend -s 2 -j 2 -a
is run, the wrong frames are generated. In particular, the second command generates the even-numbered frames but with the contents of the odd-numbered frames. Moreover, the terminal output highlights the inconsistency:
Fra:29 Mem:16.95M (0.00M, Peak 17.47M) | Time:00:00.58 | Remaining:00:00.00 | Mem:0.49M, Peak:0.87M | Scene, RenderLayer | Path Tracing Tile 132/135
Fra:29 Mem:16.89M (0.00M, Peak 17.47M) | Time:00:00.58 | Remaining:00:00.00 | Mem:0.43M, Peak:0.87M | Scene, RenderLayer | Path Tracing Tile 133/135
Fra:29 Mem:16.83M (0.00M, Peak 17.47M) | Time:00:00.58 | Remaining:00:00.00 | Mem:0.36M, Peak:0.87M | Scene, RenderLayer | Path Tracing Tile 134/135, Sample 3/10
Fra:29 Mem:16.77M (0.00M, Peak 17.47M) | Time:00:00.58 | Mem:0.30M, Peak:0.87M | Scene, RenderLayer | Path Tracing Tile 135/135
Fra:29 Mem:16.77M (0.00M, Peak 17.47M) | Time:00:00.58 | Mem:0.30M, Peak:0.87M | Scene, RenderLayer | Finished
Fra:29 Mem:16.43M (0.00M, Peak 17.47M) | Time:00:00.58 | Sce: Scene Ve:0 Fa:0 La:0
Fra:29 Mem:34.25M (0.00M, Peak 44.14M) | Time:00:00.62 | Sce: Scene Ve:0 Fa:0 La:0
Saved: '/tmp/0028.png'
 Time: 00:00.67 (Saving: 00:00.04)
where frame 29 is elaborated but frame 28 is saved.
This is a problem with using the same scene as a strip in your sequence.
Setting the start frame also offsets it's position in the sequencer.
I've made a patch to support this - D2815, although I'm not convinced the fix is a net gain.
For 2.8x it may be best to remove this ability, see: T52586
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 50.Aug 30 2017, 6:33 AM
Ok, so perhaps I am using the feature the wrong way? Suppose I want to superimpose a logo on a part of the strip. What I would do is to load the image on another channel of the VSE and use a transform to add it to the scene. Should I do it differently? Should I put everything into another scene? Maybe I can achieve the same with the compositor...
Another use case would be to stop the animation at some point to have an explanatory text appear, to later resume the animation. What's the correct way to do these things?
It's best to have a scene that's only for editing video - so you don't put the scene into its self (causing this bug).
I can confirm that using another scene works as expected. Thanks for the advise, I also noticed that inputting the same scene in the VSE brings some inconveniences.
