Win8.1x64, 3x gtx580
2.79t2
When there is no external variables defined, the driver stops updating in the viewport dynamically. Updates only on more global events like frame change.
- Grab/move the object in z axis. It curves proportionally to elevation via driver controlled modifier.
- In the selected driver, remove object reference from the defined variable or the variable itself.
- Grab/move of the object doesn't update modifier effect anymore although the expression is still valid.
