File System File attached
Windows 10
NVIDIA Quadro M2000
2.79 Official Release
While importing FBX files generated by Autodesk Revit has greatly improved and all geometry seems to com intact with instances and everything, something seems off with selecting objects. When I click on an object where other geometry is behind it it will always select random geometry in the background instead of the geometry closest to the screen.
This is not affected in wireframe mode. Nor is it an issue when I open a clean blend file. It is only with the scene where imported geometry is present.
Note it also happens when creating new geometry in the same scene as the imported geometry.
- Open the attached .blend file or alternatively import the attached .fbx file (Y forward).
- Try and select an object.
- Notice the selection is never the object clicked upon if anything else was behind it.
