master from today, only 2015/x64/release seems affected
54: Test timeout computed to be: 9.99988e+006 54: [==========] Running 2 tests from 1 test case. 54: [ RUN ] bake_split_faces 54: [ OK ] bake_split_faces (2204 ms) 54: [ RUN ] bake_zspan_watertight 54: Error: EXCEPTION_ACCESS_VIOLATION 54: [] Unknown error 'CRASH' 54: [ FAILED ] bake_zspan_watertight (694 ms) 54: [] 54: [==========] 2 tests from 1 test case ran. (2901 ms total) 54: [ PASSED ] 1 tests. 54: [ FAILED ] 1 tests, listed below: 54: [ FAILED ] bake_zspan_watertight 54: [] Report saved to: file:///K:/BlenderGit/build_windows_Full_x64_vc14_Release/tests/cycles/report.html 1/1 Test #54: cycles_bake_test .................***Failed 3.15 sec
