Create Lattice Object - Last Operator - Radius is not radius but size
Closed, DuplicatePublic
Windows 7 64 Bit
Nvidia GTX 760
Broken: (example: 2.69.7 4b206af, see splash screen)
When you create a Lattice object, then the radius prop in the last operator shows the size, not the radius. Radius would be half the size.
Open Blender, create a Lattice Object. Compare the Radius value in the Last Operator panel with the Dimensions panel in the Properties Sidebar.
