modal numinput angles units
Debian GNU/Linux 8.8 (jessie)
GeForce GTS 250
2.79 (sub 0), branch: master, commit date: 2017-09-11 10:43, hash: 5bd8ac9abfa
Using modal numinput results in an annoying behavior when scene units are not set to "radians" in case you need to specify a rotation angle as the result of acos/asin/atan functions. The result of these functions is implicitely in radians, and when scene units are set to "degrees", returned values are not transformed to degrees, e.g. acos(0.5) returns 1°. To obtain 60° one as to type acos(0.5)*180/pi.
Setting scene units to radians solves the issue but it's somewhat uncomfortable ;-)
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Oct 25 2017, 8:45 PM
Thanks for the report, but no bug here, if you use trigonometrical functions, then obviously you get radians, up to you to do the conversion. This is essentially a very limited subset of the py interpreter, we can only add a limited level of 'easiness' here, if user want to have full py power then he has to comply to py APIs etc.
OK Bastien, I agree it's logically inherent to python trigonometric functions -- i.e. results are implicitely in radians. And for whom actually uses these functions it won't be a problem to convert to degrees. But there's still something I call a bug, which is the string returned in the status bar: if I keep on my previous example, typing "r", "x" then "=acos(0.5)" displays: "Rot: [acos(0.5)] = 1° along global X", which is wrong, whatever unit you consider...
