Unexpected Fresnel Factor with Principled BSDF
I've been using the Principled BSDF node for the last few months. During this time I have noticed a fresnel transition between transparency and reflection which is too sudden. Below I will document examples which work and examples which exhibit the broken behavior.
Example on water surface using Principled BSDF as a volumetric shader. IOR is set to 1.33 and Specular to 0.5
Example showing the Fresnel node with expected smooth Fresnel response
Original V-Ray scene
Converting to Cycles, note reflection on tea using IOR 1.32 and Specular 0.5:
IOR set to 1.0:
Brecht Van Lommel (brecht) lowered the priority of this task from 90 to 30.Nov 10 2017, 1:29 PM
Please follow the bug reporting template and provide operating system, Blender version, .blend file, etc.:
https://developer.blender.org/maniphest/task/edit/form/1/
OK I will try to reproduce this problem in Blender. Currently I am experiencing it when using the cycles API directly.
I have been unable to reproduce this in the current version of blender yet. Was there any updates to the principled shader between 1.79 and 1.79.1?
There were some fixes: rBc040ded, rBd85a0a7, rB9e929c9.
Or maybe the normals are pointing the wrong way?
Hi Brecht, thanks so much for the suggestion, the problem seems to be that my normals in particular cases were flipped. I can reproduce it in blender by manually flipping the normals. Please close this for now and I will re-open if I have further problems.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Nov 14 2017, 3:53 PM
