Vertex groups selection in Edit mode is not working as expected
Windows 10 Home 64-bit, Nvidia Geforce 1060 6Gb
Broken: 2.79 5bd8ac9
Worked: used to work fine in 2.71 - 2.76 as far as I recall
Here is a video showing what's going on:
https://www.youtube.com/watch?v=fhJ2M74Vc9o
  1. Create a cube
  2. Create Armature and bones (correctly name bones and create correct hierarchy)
  3. Parent mesh to Armature with automatic weights
  4. Have every vertex group have all vertices of the mesh
From what I recall vertex groups used to be created per bones and only vertices weighted to the corresponding bone were assigned to the vertex group.
Blend file is attached.
Every vertex group having every vertex is because the cube is tiny and there are only 8 vertices. Plus all bones have Deform enabled, if you disable Deform no automatic weights will be applied for that bone. Also the bones are pointing up instead of out from the sides, the weights are using some kind of raycast so having them point a certain direction makes them more accurate. If you increase the subdivisions you should see that not all vertices end up weighted to all bones. Try it on a mesh like Suzanne instead and you will see that it works as intended.
Philipp Oeser (lichtwerk) changed the task status from Unknown Status to Archived.Jan 25 2018, 8:20 PM
Agree with @Henrik Berglund (cyaoeu) , no bug here.
