Scale, rotation
Windows 10
965 graphics card
2.79
I cannot Rotate, or scale any object in the blend file
It just seems to happen at random.
The way you phrased this is more of a support thing. Anyway you've probably enabled Manipulate Center Points next to the pivot point picker.
I agree 100% though that when scaling/rotating a single mesh with that setting enabled instead of doing nothing you would really like it to transform normally (like with the setting disabled). Aka if you've got only one object the center point is in the center of that object. If this is not a bug it's a design flaw, either way it should be improved.
Vuk Gardašević (lijenstina) lowered the priority of this task from 90 to 30.Feb 6 2018, 3:45 PM
Like it was said, most likely the option of Manipulating Center Points was enabled.
https://docs.blender.org/manual/en/dev/editors/3dview/object/editing/transform/control/pivot_point/manipulate_center_points.html
Please let us know if disabling it, solves the issue.
Setting as Incomplete until additional information is given.
Vuk Gardašević (lijenstina) changed the task status from Unknown Status to Unknown Status.Feb 14 2018, 12:38 PM
More than a week passed without a reply.
Due to the tracker policy, archiving until the required additional information / data is provided.
