Work-Spaces fail to account for multiple active windows
Current code for object modes and workspaces assumes a single window and a single active workspace.
This will not always be the case, it's possible we have two active workspaces at once in different windows, showing the same scene - with different active view layers, therefor different active objects.
So we can't assume for example, when switching to a workspace that the workspace is the only user of that object, that another window wont have that objects already in edit/sculpt/vertex paint mode - for eg.
Switching into/out of workspaces should account for all other windows active workspaces.
Since multi-window support often crashes, or shows a black viewport - this isn't very easy to test at the moment.
Keeping this task as reminder to support it eventually.
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to Normal.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.Jul 24 2018, 2:00 PM
With the latest workspace / mode design this isn't relevant anymore, and stability should be improved too.
