system 1:
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
RAM: 16GB
GFX: GeForce GTX TITAN
OS: Windows 7 pro 64 SP1
system 2:
CPU: Intel Core 2 Duo E8400 Processor
RAM: 4GB
GFX: AMD Radeon HD 6450
Broken: 2.77 and newer
Worked: 2.76b and previous
When working in edit mode with object that has array modifier assigned, it was possible to snap vertices of original mesh to vertices of clones generated by array modifier (when 'show_on_cage' is enabled). No longer works since 2.77.
Start with default scene;
select cube;
add array modifier;
disable relative offset;
enable constant offset, set offset value more than cube size by any axis (for example offset x = 3);
in array modifier enable 'show_on_cage' (Adjust edit cage to modifier result);
in 3d view enable snapping, set snap to vertex;
enter edit mode, vertex mode, select any vertex;
move selected vertex to any vertex of clone generated by array modifier
snap will catch vertex of clone only in v2.76b and previous versions
