crash in ui_def_but_rna
Windows x64.
Broken: latest master.
Worked: 2.79
strlen is called on what looks to be freed memory (ASAN will probably have a thing or two to say about this)
Open up .blend, click 'run script'
For repro on windows you need the debug heap enabled, on linux ASAN should be able to catch it.
>	blender.exe!strlen() Line 70	Unknown
 	blender.exe!ui_def_but(uiBlock * block, int type, int retval, const unsigned char * str, int x, int y, short width, short height, void * poin, float min, float max, float a1, float a2, const unsigned char * tip) Line 3182	C
 	blender.exe!ui_def_but_rna(uiBlock * block, int type, int retval, const unsigned char * str, int x, int y, short width, short height, PointerRNA * ptr, PropertyRNA * prop, int index, float min, float max, float a1, float a2, const unsigned char * tip) Line 3575	C
 	blender.exe!uiDefButR_prop(uiBlock * block, int type, int retval, const unsigned char * str, int x, int y, short width, short height, PointerRNA * ptr, PropertyRNA * prop, int index, float min, float max, float a1, float a2, const unsigned char * tip) Line 3831	C
 	blender.exe!uiDefAutoButR(uiBlock * block, PointerRNA * ptr, PropertyRNA * prop, int index, const unsigned char * name, int icon, int x1, int y1, int x2, int y2) Line 112	C
 	blender.exe!ui_item_with_label(uiLayout * layout, uiBlock * block, const unsigned char * name, int icon, PointerRNA * ptr, PropertyRNA * prop, int index, int x, int y, int w, int h, int flag) Line 722	C
 	blender.exe!uiItemFullR(uiLayout * layout, PointerRNA * ptr, PropertyRNA * prop, int index, int value, int flag, const unsigned char * name, int icon) Line 1468	C
 	blender.exe!rna_uiItemR(uiLayout * layout, PointerRNA * ptr, const unsigned char * propname, const unsigned char * name, const unsigned char * text_ctxt, int translate, int icon, int expand, int slider, int toggle, int icon_only, int event, int full_event, int emboss, int index, int icon_value) Line 126	C
 	blender.exe!UILayout_prop_call(bContext * C, ReportList * reports, PointerRNA * _ptr, ParameterList * _parms) Line 1428	C
 	blender.exe!RNA_function_call(bContext * C, ReportList * reports, PointerRNA * ptr, FunctionRNA * func, ParameterList * parms) Line 6474	C
 	blender.exe!pyrna_func_call(BPy_FunctionRNA * self, _object * args, _object * kw) Line 5673	C
 	python36_d.dll!_PyObject_FastCallDict(_object * func, _object * * args, __int64 nargs, _object * kwargs) Line 2316	C
 	python36_d.dll!_PyObject_FastCallKeywords(_object * func, _object * * stack, __int64 nargs, _object * kwnames) Line 2481	C
 	python36_d.dll!call_function(_object * * * pp_stack, __int64 oparg, _object * kwnames) Line 4836	C
 	python36_d.dll!_PyEval_EvalFrameDefault(_frame * f, int throwflag) Line 3312	C
 	python36_d.dll!_PyEval_EvalCodeWithName(_object * _co, _object * globals, _object * locals, _object * * args, __int64 argcount, _object * * kwnames, _object * * kwargs, __int64 kwcount, int kwstep, _object * * defs, __int64 defcount, _object * kwdefs, _object * closure, _object * name, _object * qualname) Line 4139	C
 	python36_d.dll!PyEval_EvalCodeEx(_object * _co, _object * globals, _object * locals, _object * * args, int argcount, _object * * kws, int kwcount, _object * * defs, int defcount, _object * kwdefs, _object * closure) Line 4166	C
 	python36_d.dll!function_call(_object * func, _object * arg, _object * kw) Line 604	C
 	python36_d.dll!PyObject_Call(_object * func, _object * args, _object * kwargs) Line 2246	C
 	blender.exe!bpy_class_call(bContext * C, PointerRNA * ptr, FunctionRNA * func, ParameterList * parms) Line 7757	C
 	blender.exe!panel_draw(const bContext * C, Panel * pnl) Line 148	C
 	blender.exe!ED_region_panels(const bContext * C, ARegion * ar, const unsigned char * context, int contextnr, const bool vertical) Line 1920	C
 	blender.exe!buttons_main_region_draw(const bContext * C, ARegion * ar) Line 147	C
 	blender.exe!ED_region_do_draw(bContext * C, ARegion * ar) Line 522	C
 	blender.exe!wm_method_draw_triple(bContext * C, wmWindow * win) Line 610	C
 	blender.exe!wm_draw_update(bContext * C) Line 1000	C
 	blender.exe!WM_main(bContext * C) Line 523	C
 	blender.exe!main(int argc, const unsigned char * * UNUSED_argv_c) Line 529	C
 	[External Code]
I didn't check if it's the same issue, but there is a documented bug that sounds similar:
https://docs.blender.org/api/2.79/bpy.props.html#bpy.props.EnumProperty
@Brecht Van Lommel (brecht) yes, thats the bug. We could workaround this by over allocating the return value of enum_items_from_py, storing the string data at the end.
While this would backfire if Blender ever tries to copy the enum, I don't think we do this at the moment.
Another option could be to allocate or intern strings and have a flag in each EnumPropertyItem to mark is as different.
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Unknown Status.Mar 29 2018, 9:00 AM
Archiving since this is a known issue.
