Dissolve loop in vertex mode gives bad geometry
Windows 7 pro 64 (6.1 7601) Intel HD 4600
Broken:
  1. blender-2.78c release-windows64
  2. blender-2.79.0-git.1ebc140-windows64
  3. blender-2.80.0-git.6456d59-windows64
ctrl + x gives bad geometry for vertices loops
  1. Select default cube
  2. Go to edit mode
  3. Select all and subdivade simple x2
  4. Switch to vertex select
  5. Select (single or multiple parallel) vertex loop and dissovle it by ctrl + x
PS. It apears that the same operation on flat surface works as dsired
Piotr Kudzin (sng84) updated the task description. (Show Details)
You don't need to add tags: BF Blender 2.8 & Platform: Windows. Unless your issue is only in 2.8 or only on Windows.
Piotr Kudzin (sng84) lowered the priority of this task from 90 to Normal.Apr 2 2018, 3:47 PM
Piotr Kudzin (sng84) changed the task status from Unknown Status to Archived.Apr 3 2018, 7:09 PM
I don't know why but i was expecting same/ similar behavior as with edge loop disolve, and just realized my mistake, case cloed!
