i am trying to install the blender docs system on win 10 so that i can help edit the docs. i have followed or tried to follow the instructions on these pages:
https://docs.blender.org/manual/en/dev/about/contribute/install/windows.html https://docs.blender.org/manual/en/dev/about/contribute/build/windows.html
things seemed to go all right with the install, though i got this text in red:
Exception:
File "c:\program files (x86)\python36-32\lib\site-packages\pip\basecommand.py", line 215, in main status = self.run(options, args) File "c:\program files (x86)\python36-32\lib\site-packages\pip\commands\install.py", line 342, in run prefix=options.prefix_path, File "c:\program files (x86)\python36-32\lib\site-packages\pip\req\req_set.py", line 784, in install **kwargs File "c:\program files (x86)\python36-32\lib\site-packages\pip\req\req_install.py", line 851, in install self.move_wheel_files(self.source_dir, root=root, prefix=prefix) File "c:\program files (x86)\python36-32\lib\site-packages\pip\req\req_install.py", line 1064, in move_wheel_files isolated=self.isolated, File "c:\program files (x86)\python36-32\lib\site-packages\pip\wheel.py", line 345, in move_wheel_files clobber(source, lib_dir, True) File "c:\program files (x86)\python36-32\lib\site-packages\pip\wheel.py", line 316, in clobber ensure_dir(destdir) File "c:\program files (x86)\python36-32\lib\site-packages\pip\utils\__init__.py", line 83, in ensure_dir os.makedirs(path) File "c:\program files (x86)\python36-32\lib\os.py", line 220, in makedirs mkdir(name, mode)
PermissionError: [WinError 5] Access is denied: 'c:\\program files (x86)\\python36-32\\Lib\\site-packages\\pytz'
also i got this in light green text:
You are using pip version 9.0.1, however version 9.0.3 is available. You should consider upgrading via the 'python -m pip install --upgrade pip' command.
i tried to upgrade pip, but the upgrade failed. i have no idea whether any of the above matters - are they warnings or errors? well ok, they are exceptions, but i don't know what exception means in terms of severity.
the real problem, however, is when i try the 'make' command on the build page. i get this:
c:\blender_docs>make No command given, defaulting to html. 'sphinx-build' is not recognized as an internal or external command, operable program or batch file.
i have tried explicitly installing babel in case it didn't get installed during the requirements.txt phase, but i still get the same error when i try the 'make' command. i completely stuck i think until and unless i can get past this blockage.
thanks,
julian
