Ubuntu 17.10 NVIDIA Corporation GT216M [NVS 5100M] (rev a2)
KDE Plasma Version: 5.10.5
KDE Frameworks Version: 5.38.0
Qt Version: 5.91
Kernel Version: 4.13.0-038-generic
OS Type: 64-bit
Broken: 2.78.c (installed with sudo apt-get install blender)
Blender crashes after using scikit-image and returns this error message:
QH6248 qh_lib_check: Incorrect qhull library called. Caller uses reentrant Qhull while library is non-reentrant QH6249 qh_lib_check: Incorrect qhull library called. Size of qhT for caller is 8184, but for library is 2896. QH6255 qh_lib_check: Cannot continue. Library 'qhull 7.2.0 (2015.2 2016/01/18)' uses a dynamic qhT via qh_QHpointer (e.g., qhull_p.so)
- Installing scikit-image to python by sudo pip3 install scikit-image
- Running blender -b --python-console or within the interactive console in Blender
- Type in console: from skimage import measure and this produced the previous qhull error.
Note: This error occurs only when running skimage within Blender and not with Python alone. The same error occurs for from scipy import spatial when having scipy installed to Python
