Here's a list of our active tools, and how they should be ordered:
Object Mode
- 3D Cursor
- Box Select
- Circle Select
- Lasso Select
- Move
- Transform
- Rotate
- Scale
- Scale Cage
Edit Mode: Mesh (done rBa44d5b59d35d3f6da2b31137cd06b14a3aa71631)
- 3D Cursor
- Box Select
- Circle Select
- Lasso Select
- Move
- Transform
- Rotate
- Scale
- Scale Cage
- Ruler
- Extrude Region
- Extrude Individual
- Extrude to Cursor
- Inset Faces
- Bevel
- Loop Cut
- Offset Edge Loop Cut
- Knife
- Bisect
- Poly Build
- Spin
- Spin Duplicate
- Smooth Verts
- Randomize Verts
- Edge Slide
- Vertex Slide
- Shrink/Fatten
- Push/Pull
- Rip Region
- Rip Edge
Sculpt Mode: (done)
- Draw (D key)
- Grab (G key)
- Thumb
- Snake Hook/Extrude (K key)
- Blob (I key)
- Inflate
- Smooth (S key)
- Flatten (X key)
- Scrape
- Fill
- Crease (V key)
- Pinch/Magnify
- Clay (C key)
- Clay Strips
- Layer (L key)
- Nudge (R key)
- Rotate
- Mask (M key)
