Windows 10 64 bit, GTX 980 Ti, rendering on i9-7900X
Broken:
2.75a c27589e
2.78c e92f235283
2.79b f4dc9f9d68b
2.79 5740505 (latest build)
2.79 60f4cb2 (latest build, win32)
2.80 cfa1700 (latest build)
Worked:
2.70 19e627c
A trivial OSL Script Node in Cycles where trace(a, b) and then getmessage("trace", hitdist", dist) is called and result is passed to mix node crashes Blender with EXCEPTION_ACCESS_VIOLATION on render. I experienced similar crashes even when trace/getmessage weren't being called, but this particular example was easiest to reproduce consistently.
Open attached .blend file, switch to rendered viewport shading or hit render to instantly crash Blender.
